Removing body panel under taillights?
Hey guys, can anyone tell me if and how the sheet metal below the taillights is attached? I have a small dent in the corner just as it rounds to the side and I’d like to pulll it off, fix the dent, and repaint it. If anyone know pls gimme a clue as to how to get this thing off. Thanks
Jim
remove the plastic panel in the hatch . There are four nuts that hold that panel on, 2 on each side they are about three inches apart and are vertical ( one lower , one upper). remove th enuts and pull on the outside, The panel should pull off easily. I hope that helps.
