hwo to remove the crank??? everything unbolted just cant figure out what need to come off to remove it…pics will work good too
What exactly did you remove? Once the rear main plate, oil pump, and rods are gone, you only have to unbolt the 5 main caps, then lift out the crank.
ova by the flywheel shoud come off right??
it’ll come out w/ a little prying, it probably wont come right off cuz there is probably some silicone to seal the crank case by the oil pump, at least there was on mine. but ya, just remove the flywheel, connecting rods, and main bolts and lift the bitch out.
-Q
yea just use a lil muscle and got the thing out…its liek tha honda bond shit pretty strong
