Outside of the bolts Under the hood and hooked up to the side markers how many screws-bolts are there in the inner fender-well once i remove the splash shields the fender should come off, Correct?
There’s a total of nine 10mm bolts that have to be removed (3 under hood, 1 behind side marker, 2 behind the front bumper cover bracket, and 3 near the door hinge). After removing the fender liner screws, the fender should be able to be taken off. There are actually only 5 screws (2 metal, 3 plastic) that attach the fender liner to the fender.
