So I got my replacement ICU in the other day (thanks darussianone!), but I got stuck at removing the big connectors on the upper sides of the fuse box. I worked on the clips with a screw driver like I did with the other smaller connectors in the middle, but they would not budge. :bang:
I quit when I started getting mad, because that’s when I end up breaking something.
Here is what I did to remove the ICU removed the bottom bolt, then the 2 conectors on the left hand side of the fuse holder, pulled out enough to pry off the ICU and disconnected the 2 contector on the ICU. Put it back out in reverse order…To bad you didn’t live near me because I would have you come over and I would do it for you…
Thanks! I did what you said and I was able to successfully replace it.
Defroster and everything else related to the ICU now works.
