OK iv been thinking about taken it off because after seeing one without it…it looked sooo sweet. So I really want to take it off but what kind of plug do I need to fill the hole? I asked Acura and they were clueless. Figured I’d get some help from ya’ll.
go to teg tips
I saw a post that says that there is a gomet in the firewall that fit perfectly the hole, I looked at it, and there is a plug that fit, just take it out and put it in your hole
result is :
where is this mystery gromet at?
hum, just look at your firewall, driver side, beside that brake booster, you’ll able to find it easily, there is not much gomet that is that shape and taht fit ;o) just use some silicone to glue it there and to prevent water leek! GL!
Uhhh, Im not putting anything in my hole!
What about the hole in the firewall after you perform this “procedure”?
That grommet was there for a reason…
yeah… probably… I dont think anything can go in there… its almost high… but if you want you can put someting like ducktape to cover it hehe:)
