Hi everyone, just want your help about removing the cassette player, so I may put an aftermarket cd player in it, any screws or tools requirement ? thanks
There are 2 or 3 8mm bolts that need to be loosened behind the radio before it can be removed. After the 2- 3 bolts are removed stick you fingers into the tape slot and pull twordes the e brake handle. The radio will pull out easily with the map pocket attached. You will need a dash kit and a wire harness adapter to install a new radio.
no special tools required. just a set of screwdrivers in a variety of sizes/lengths.
thanks! i’ll get right to it tomorrow morning…
