OK. so I have remove the steering column so far and removed the bolts that hold the brake booster. how many bolts hold the assembly? is it one piece? how can be the whole assembly removed?
i know theres like 3 or 4 on the firewall and i think 2 above it so i think in total like 5 or 6 plus the booster holds it on also il double check i just removed mine last weekend
After the for bolts for the booster have been removed there are 2 more on the firewall in the upper left and lower right corners and the if you look up above the brake pedal(laying on your back) you’ll see there is on more up there
