removing window
I need to remove my driver side window so i can tak out the handle so i can replace the keyhole some little F’ers jacked up. I dont have any manuals to help me, and when i took off the panel,it looked alot harder than i thought. So do i need a manual to guide me or is it pretty simple?
anyone?:sad:
i have no idea…but i posted to keep your post at the top.
You don’t have to remove the door glass to get the door handles off. All you need is a 10mm wrench and some time. You can also just remove the lock cylinder without pulling the door handle. The cylinder is held on by 1 clip. I removed both handles on my car when I sent the car out to be painted. It is a little hard to get to the 10mm nuts but it can be done. I do recomend using a ratchet type wrench.
