renewing your door panels
I know what you mean by the seams comming up… dammit just had them done a week ago and it is comming appart. plus i couldn’t get the cuts around the seams perfect. is there some sort of seal we can make around the pieces we replaced?
When It Dries Just Use Rubber Cement Around The Edges It Should Stay Put…
Does anyone know how to remove the bottom panel shown here? I know there are 4 phillips screws on each corner - but there also clips along the bottom side. Not knowing they release, I don’t want to break them. Tried gently using a flat-blade to see if they would release with a bit of pressure.
so did anyone ever post up a glue that will hold and where to get it? also to 1SickG2 what glue did you use and is it still holding? i think some dark suede would be sweet. but i dont want to start and then have to redo it every month cause of the glue issue.
Yes It’s Still Holding Up Very Well…
I Used 3M Spray Adhesive From Office Depot They Also Sell It At Home Depot As Well. If You Want Extra Assurance You Can Use Any Rubber Cement On The Edges
cool thanks, and another thing i thought of… should i stay away from any certian fabrics?
Bump!. ima do this tomorrow. did u have to remove the old fabric. or is it part of da panel. and just double layer it. right?
i think its best to remove old fabric to get the proper adhesion to the door panel
that armrest came off the JDM DAs…
