my axles badly need replacing, the crack around turns and while accelerating. i need to know though, is this a do it yourselfer job or should i take it to someone? can things be really messed up if i dont do it right or is there no wrong way to do it? i have done alot of other things myself, but this is a first for axles and thats why i’m asking. anyone with experience doin them could really help me out.
I just did mine. If you can get the axle nut off without too much drama, then the rest of the job is definitely reasonable.
I can tell you a trick I learned to get the ball joint/LCA loose.
E-mail me if you wish.
Also, try a :search:
