Replacing foglight bulb
Call me a dummy;but I can’t figure out for to change my foglight bulbs. I have one burnt out so I’m changing them both. Could someone please help me? It would be greatly appreciated.
esiest tip, don’t be an idiot and try changing the bulbs with the fog housings on there specially if you have stock intake… there are 1 screw on each fog light housing at the side when you pop the hood, take those off, the entire fog housing then unclips off the other side and then you will ahve the complete thing in your heand easier to work with… then pop off the rubber dust cap seal on the back of the fog. after that. thre is a push spring the overlapts the H3 buklb, push it in and unhjook it then it’ll slide off, then the h3 bulb should come right out, d/c wires, redo the same but in reverse to install new ones. :slight_smile: hopefully I made sense?
