replacing the rad support
A few days ago my gf crashed my integra. and now i need to replace the rad support on it. but its my first time doing it and i dont have the money to take it to a shop so i need to do it my self. so i was just wondering if any one has a write up on how to do this. or if you got any tips so i dont mess anything up.
thanks.
two words:
TEG TIPS!!
the other one is played out.
i have searched the teg tips i have searched hits whole forum and i cant find a thread about changing the rad support.
if you can help me find one that would be great.
Well first off you would have to disassemble the front body panels, then you unbolt everything that you can from the radiator support, the next thing you do is get a spot-weld cutting bit and cut every single spot weld out. I dont remember the exact number on my friends crx that we did but i think it was 60 even something like that. After that it should just pull right off then you grind down all the old spot weld material off the frame, and spray all the bare metal with weld through primer, and drill the appropriate holes in the new rad support depending on what kind of spot welder you have. Weld it all up and put the car back together and it should be done. O and sorry if the sentences are kind of jumbled together, its been a long day. I forgot to mention you could just weld it in a couple areas and bolt the rest together, the first way is just the proper way.
took about 2 minutes of looking in teg tips
http://www.g2ic.com/forums/showthread.php?t=124613
oh my bad i was looking for something to say radiator support replace. sorry but thanks for the link.
