I haven’t ridden my Teg only but the drive home. The reason I posted this was becasue i was planning to swap it for a newer trans since on the drive home the trans jumped on the 1st and 2nd gear but was alright in the other ones. I went with the thought that my clutch is bad but if it was then maybe i couldn’t make the drive home. One more thing, how could i make sure my tranny is a regular tranny and not a vtec model and is it worth it to rebuild even if it is faulty?
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
