This is probably deadly…but what if you were to reroute your A/C lines, or at the least the cold air that comes from it, into the intake, therefore resulting in colder air and more power…
Would this idea work? Has it been done before? Need opinions.
its probably not goin into the supercharger like intake air is going in. its prabably going into the supercharger for cooling purposes (separate chambers) but not for intake air purposes.
The lightning uses an intercooler I think. If it does they probably rant he A/C lines through the intercooler. That would make more sense then running it to the intake. The intercooler would be close to the A/C condensor so you wouldn’t need much extra A/C lines and it would provide a damn cold air charge for the supercharger. It isn’t the first time this has been done. Just a thought, I may be wrong.
EDIT: I just checked with the SVT website. The Lightning uses a small storage tank that the A/C system chills to about 30 degrees. On demand the tanks contents are dumped into the intercooler reducing temp there by up to 20%. This in effect delivers up to 50 extra hp for about 35-45 seconds. Not a long time but in a race that would be like punching a 50 shot of NOS. Pretty ingenious.
-Ian
Insted of running or a/c into your intake, why not just get that Cry02 setup i saw in summit. It costs like $400for the system, then $150 for the intake cooler, and another $130 for the fuel cooler. They say it can lower your intake temp by 60%. Somebody should look into it. I think it costs a little too much.
It wouldn’t be a good idea, because if you think about it, go WOT down the street with the a/c on and off. The car bogs significantly and loses so much power when the a/c is on. It wouldn’t do the car any good cuz its straining from the a/c pump.
The ford can do it because it has a bigger engine and it doesn’t matter.
But a cool thing would b, like some saab’s have is the a/c going into the glovebox so you can keep food and drinks cold! Warm soda is just gross!
ive never noticed the a/c to cause a significant hp loss, just a slight tug when i flip it on and off. i have however felt a noticeable gain between 65F and 85F+ weather…
why dont u just put a block of dry ice in ur engine bay lol…i bet the extreme hot + cold will crack/warp the metal in there. Either that or ur car will never warm up. I think pro drag racers have ICE boxes literally filled with ice just for one run and maybe to take up strategic weight due to restrictions - fuel lines, intake, oil ines, intercooler all that shiz runs through it to cool it down fast. The drag race only lasts 10 seconds so it wont have time to completely melt before it does its job.
THe Cryo2 thing on summit sounds like a pretty good idea, but that’s pretty hardcore for the price and it also needs to be refilled. Essentially it’s like shooting liquid CO2 and dry ice onto ur intake tube, fuel line or intercooler. It probably works, but ur gonna have to refil that bottle often just like a C02 powered paintball gun.
As for the A/C thing i think that’s silly, but it probably has been considered. I had no idea ford uses this technology. Ever hear of water injection? COoling the engine internally and directly in order to make it more dense probably works best. Anti detonation is always good. The car wont have to retard timing as much which reduces the power to save the engine from detonation the standard way.
If youre really into this idea than u should look into that cryo2 stuff from summit. I think it would work to some degree but i wouldnt pay over $150 for something as simple as that.
Well im not crazy enough to pursue my idea. I was just doing brainstorming and sharing my ideas with other people. Thanx for the info anyways though. Maybe someday when I am working on cars and trying to make them fast I will think about this post.
