I replaced my head gasket and torqued the head bolts (new oem headbolts) to spec…but i read that you have to retorque some headbolts after a certain milage, im not sure if this is true or if its just for aftermarket studs/headbolts. Not sure if i need to retorque new oem head bolts.
yea i would go through all of them and retorque it with the same torque spec
do NOT retorque your stock headbolts. that only applies to the aftermarket studs.
