me and a friend are doing a retrofit and i was wondering how do i sand the flutes down so that they are clear? is there a special way or do i just use any sand paper or w/e any help will be helpful =D
Retrofit what? 94
to hid probably. search for the hid retrofit thread. there is a lot of info on there. i personally got a set of headligts with clear lenses to avoid all of that sanding. yes, you would have to sand them down with handpaper or some sanding disk and then polish the plastic so that it is clear. look around and you’ll see more info.
yea retrofit lights =P ok ok yea like today i tried sanding them down working from 600 to 2000 grit then i will try to get a nice clean polish from it is meguaries plastic x a good polish kit to use ?i heard the megauries arent that good to use. because thats is the only stuff i see available around but i think i can get some stuff better online.
