Just bored and thought I’d open up discussion on rev-limiters debate. Quick brief what is done to your engine.
How often you you hit the rev-limiter on a stock engine? Does it bother or worry you? How stout is the b18?
I’ve got 329,000km’s on a stock b18, its very tired but runs like a champ. Intake and exaust work with advanced timing is my setup. I hit rev limiter about 3+ times a day mostly due to the fact I like how it sounds. I dont seem at all worried about blowing it up, afterall it I blow it up than I get to build a engine. Just getting others opinions on this. I have never hit a limiter until auto-x last summer and I’ve been hitting it ever since. Racing, you’re into the rpm’s for a long period of time vs limiter while driving.
From another post "A rev limiter is simply a limiter. Its not like the engine is bouncing off its natural 100% limit|
Rev-limiters are ON OFF switches for the engine. Each time you hit it the whole drivetrain has a big shock. If you are racing that limiter slows you down. If you care about your car I don’t really see how the sound of the limiter offsets the abuse done to the drivetrain.
Make sure your oil level is good. Get an oil temp and pressure gauge. Racing abuse should only be conducted if the oil is up to pressure and the temps are at least 180 deg F.
I hit my rev limiter today… does that mean that I get a new engine?
Driving style and the engine’s internal condition are the two main variables. You can blow up an engine in many different ways, but occasionally revving out a gear is usually not the most common cause. If you’d like some pointers on blowing one up, I’m sure my brother can give you some (I would assume constant WOT and lots of hard downshift are good for stretching out the stock rod bolts… and continuing to drive like that after you begin to hear it knock probably helps even more… at least in my brother’s case).
