Reverse Lights Not working.
My reverse lights don’t work. I’ve checked the bulbs and and replaced them with fresh ones, no luck. All the wires are intact and nothing is corroded.
Any other possible solutions you guys can think of? It’s a bit frustrating cause I have to use my emergency lights whenever i reverse haha. Car is a 4dr 90 gs 5spd .
Fuse must be good, [if signal lights work], I would check the “Back-Up Lights Switch” on transmission.
Unplug the switch and jump the two leads, [green/black and yellow] turn on ign., if back up lights turn on, replace the switch.
If not, check for power on the yellow lead, [ign. on] if power present, there is a connection problem between the switch plug and the back-up lights. 94
