does anyone know how to tap the reverse lights to the defroster switch in my integra…if so can you please explain to me how in detail thanks…
fyi, white lights in the rear are illegal in california. white designates oncoming traffic…
i know but i wasnt planning on running it all the time … just use it to call people out …
instead of using hazards… to let your friends know behind you where you are…
Cut the black/green wire going to defroster and splice into grn/blk at reverse light
Blk/grn found at c503(8-grn) pin 3 at top rear dash fuse box.
grn/blk found at c408(14-red) pin11 on dash fuse box.
i would also disconnect radio noise condensor in driver kick panel
info from helms etm section 62 and section 112
why dont u just use the hazards?? its brighter…
