well the 5-spd swap is now complete and i have a problem, the car does not shift into reverse and i tried the 2nd to reverse trick and no luck, anything else i can do before i drop it again and fix it?
isn’t it 4th to reverse and not 2nd???
Does it start finally?
:shrug:
Oz
yea it does finally start
is it an advance job to put in a new reverse gear, i suppose what i’m trying to say is, should i take it to a shop or should i do it with some members?
what did u find out the problem was?
i didn’t, i’m assuming i have to replace it because no one has replied with anything i can do.
Sometimes on cold morings my car doesn’t want to get into reverse also, so I put it in 1st and full forward a bit (not very much, less than a foot) and then put it back into reverse. It works for me.
