oh and that is located right above your fuse box on the inside driver side under the dash
Alright, I’ll try that… I also have doorpoppers so it could be a short in the passenger door side as its not working right now :S… I’ll check your way as well as my poppers thanks bud! hey do you have msn and use it at all? haha if you do pm it to me or something!
[QUOTE=JDMIntegraDA;2084323]just go by this diagram someone gave to me works great all i did was run my fogs into it with a fuse block in between and it works great
Thanks buddy! but we already got that one figured out… but this would be a good thread for anyone else interested in running their fogs when their car turns on (its illegal in canada to not have DRL’s)
the test light does not come on at all :(, any other ideas?
If the test light does not come on you do not have a parasitic draw, the problem is the batt. itself. 94
I got the battery tested… Came back good… maybe the alternator?
You said, "my battery dies after 3 days… does that mean 3 days of driving or 3 days just sitting not running? 94
not running
If batt. dies without car running then it has to be a parasitic drain or a bad batt., how was the batt. tested??? 94
the batt tested fine, changed the alternator, no long have the problem… guess it was diode backdraw from it…
