Rewiring fog lights help
the fog light switch is on the left side of my steering wheel and the rear defrost switch is on the right side of my wheel. I dont see how i can get the wires to go all the way to the other side of the wheel. Is it possible to wire them to the cruise control switch? cause that is right next to the fog switch. my cruise doesnt work anyway. Thanks guys
Extend the wire.
My defrost switch doesn’t stay in though. Do I have to press it in or will it work without it being turned on?
it doesnt have to be on
Don’t use the defrost switch, [or CC switch] use the park light free pin in the under dash fuse box. 94
Wouldn’t that force u to once again turn on the Lights b4 u can turn on the fogs, even tho its just parking lights?
Yes it would, if you do not want that, use the 2nd ign. free pin, [hot in run only] or if you are into taking a chance use the 12V constant free pin [hot at all times] although that will kill the batt. in no time if you forget them on. 94
im just gonna run a longer wire over to the defrost. what size wire should I use?
Ok I did it. Took alittle work with a clothes hanger to get the wire through but I got it done and i’m really happy with the way it looks. Thanks for all the help guys.
