Rewiring fogs on a 90 GS.
I recently tried rewiring my fogs just like the Teg Tips said. Only to remember that my trim is a GS not an RS/LS, so therefore I have DRL (Daytime running lights). So my question to all you DA gurus is how do I get my fogs to be my DRL’s?
You want your fogs to be the DRLs or also come on with the DRLs?:hmm:94
Sorry I was in a rush when I made this post. I had just rewired my fogs last night and it worked and turned on with my headlights as my DRL’s. However, I wish for ONLY my foglights to be my DRL’S and nothing else. I was just wondering if anyone else had done this to a 1990 GS.
It is possible, you will have to rewire the output from the DRL relay, red/blue on a 90 and white/red on 91-93 G2 from the high beams to the fog light switches red/blue lead, parallel connection.
If it is a 91-93 you can rewire from the DRL resistor packs output, [red/green and red/blue] to the fog lights, [after the fog light relay] also parallel connections.
You may want to check and see if it is legal to use the fogs as DRLs.:whisper: 94
