I am building my b17 N/A and right now I am concentrating my efforts on the head. My question is whether it is a good idea to go a little over kill on my cam now, in comparison to what I have in the bottom end, and not have to upgrade later when I decide to take it up a notch in the future?
My build goal is a fairly stable idle with a power band that would be fitting for a 4-2-1 exhaust header (8-9K rpm redline). used for recreational spirited driving and i have a daemon chipped ecu so i will be tuning.
If you have a low compression (stock) block and an unported head, you can actually lose power by getting too aggressive of camshaft setup.
I would think a Tuner 1 Skunk2 camshaft/valvetrain setup would work for you. Much more aggressive and you’ll be kicking yourself.
The mods for the first build I am looking to do that concentrated mostly on the head is still going to include pr3 pistons that will up my compression from 9.5:1 to around 10.8-11:1 depending on machine work and headgasket and valve and cumbustion cc work etc. What about PCT pistons with a CR of around 12.5:1( roughly)? If this setup is even safe on a b17 is still controversial.
with a CR of 12.5:1 you’d be able to get a pretty agressive cam. you’ll need to upgrade the valve train if you want to rev to 9k though, or else you’ll get valve float. instead of using the PCT pistons, i would just get a forged set up, and get it balanced,
I would stick to the pr3 pistons. That way you could use a cam more aggressive than stock and have fun with the car. If you go too raced out, thats when you get the rough idle. I used the CTR’s in my b17 and they popped outta the block. Its because CTR’s are a little longer. If you do the math CTR’s can pop out as much as .03" out of the block. There is a few threads were guys have talked about this problem.
As far as the aggressive cam, and rough idle thing… My brother has Pro1s on his car and the idle is fine. It all depends on the tuner.
But true, selecting a cam that will compliment the rest of the mods is the main goal.
yeah but I wouldn’t consider pro 1’s aggressive. I think with the pr3’s and pro 1’s would be a good combo for what the guy wants. I just don’t think he would end up liking a pro 3 profile for a DD. I got 11:3ish compression with buddy club 4 cams and I like them. I have no problem rolling around town hollering at hoes
Lol… yeah, Pro2+ you don’t want in a daily driven car, for sure.
And I just saw where you’re from… fawk, I miss SD.
I would go with OEM itr or ctr cams, they offer good power and are cheaper the aftermarket. I wouldn’t go bigger in cams unless you had more displacement to fully use the more air. Some people may be quick to under estimate the type r cams but when I had my itr swap it was so quick people thought I had a B20v.
If he has high compression pistons and a ported head, he could make more power with a more aggressive cam. Especially if he plans to rev higher than 8,200rpm, which is where CTR cams begin to fall off.
And BNIB Type-R cams cost $600+ (from acuraoemparts, more expensive if you order straight from Honda)… that’s right up in the same area as aftermarket cams.
I’m not the biggest cam guru but after comparing the lift and duration numbers compared to what i have stock against what the tuner 1’s and pro 1’s and stage ones have I notice that even if the idle is still good with a pro series cam it has way more lift then i will ever need. Yes i believe a good tuner can help the car to run smoother with the right adjustments, but at what cost to the potential performance of the new mods i. e my new pistons and ported heads. I am trying to find a cam that fits my intended purpose, not just make a cam work with my setup with tuning compensation at efficiencies expense.
Dialing in idle and cold-start characteristics have no bearing on the rest of the rpm band, as it will ALL be tuned.
Over-camming is something you want to avoid, definitely. I would go no bigger than a Pro1… id think a Tuner1 work well.
How about ask a reputable tuner or motor-builder what their thoughts are?
Endyn Bumpsticks are good cams too from what I hear.
Look into kelford cams and valve train.
smooth running. a bit more pricey though.
