Right Turn signal when Braking?
As the title states, for some odd reason whenever I brake my right turn signal in my taillights turn on. This happened immediately after I put them back on after taking them out to put in new taillight gaskets. Also, if I take off my taillights which in turn mean I have to take the gaskets out, will this make my gaskets less effective? The reason I ask is because I had an enormous leak before due to horrible taillight gaskets. Thanks fellow Teggers.
Do the brake lights come on when you use the right turn signal?
It sounds like you may have “pinched” some wiring when you reinstalled the tail light housing.
Also is it possible the bulbs have gone back into the wrong sockets?:hmm:94
thanks for the help. I will definitely check it out, right away. All the rear lights are functional, this is the only dysfunctional thing going on.
