Right Wheel Specs?
Yeah i posted in another section but i decided to post this one here. It was about the lug specs and i know i need 4100 but the 114.3 i’m questioning? Will these work? Out of the 17 inch i’m think the only ones that will work is the 4 lug, 4100/114.3. Am i right? Thanks fellas
http://www.enkei.com/Performance%20specs/evo5.html
if it has both sizes then there are 8 holes just like the pics in the link, this makes them pretty much universal for most 4 lug applications. the 4x100 is the size you will use when you put them on
White_Teggy is right. Just to expound on what he was saying…
G2 Integras (stock) use 4X100 lug pattern. Unless you’re swapped with something else like ITR hardware, then you will need wheels with 4X100 lug pattern wheels.
Many 4-lug wheels are actually 4-lug universals. This is not to say they’ll fit ANY 4-lug application, but they’re drilled with 8 holes, 4 are in 4X100 configuration, and the other 4 are for 4X114.3 (or sometimes 4X108)configuration. This makes inventory management easier for the wheel manufacturer, because they can have only one part number for many different applications.
Again, unless you’re swapped, you MUST HAVE 4X100 lug pattern on your wheels.
sorry to jack but i just put my 17’s + yokohama rubber with muteki open ended lugnuts…what should i torque the lugs to?..and i know not a impact wrench…im using a clicker
well factory specs are around 80 lbft
399-770-0142HS +42offset 4 x 100/114.3 72.6 dia 17x7
So these will work? 4 x 100/114.3 so this means is made for both?
The wheels you describe will bolt on, yes.
