right wheel sticks out a little, need help fast
I don’t know what the problem is. I’ve tried wheel alignment and even changed the axl assembley, ball joints and all. Is it because the car is lowered on springs? Will it be fixed after I get a camber kit? It gets a little dangerous on the highways because the car pulls to the right, especially at higher speeds.
the whole thing sticks out, or just top or bottom? Sounds like you mighta slid into a curb and bent your control arm or something.
did u get ur wheel balanced?
why would that have anything to do with the actual wheel sticking out?
Have you tried checking the psi of the all the tires?
I had an accident but I changed the ax assembley to correct the problem. I also had the alignment, wheel balancing and rotation done after the change. The tire doesn’t stick out like it was on spacers or anything but when I keep the steering wheel completely straight, the right tire looks as if I am turning right.
check your sub frame the samething happened to me and i found out that i had to put on a new sub frame.:rocket: :gun: :gun2: :getsome: :defend:
