The thickness of the ring will depend on which B20 motor you have. I see you say that you have a B20Z2 just order the stock rings for it. I do not know about that motor but a B20Z cames in the Honda CRV from 1998 -2001
Yea, it’s that engine. But I’m on a limited budget, and was just going all stock on it. No high compression or anything, just your typical I/H/E, as well as a lightweight flywheel.
I’m just going to get some NPR rings. I’ve done my reading, and I know some have had bad, but plenty have had good. So really, I’m not sure which set to get because I’ve found both that say it’s for the Z2 block, but have gotten ones that are 1.2 and ones that are 1.5.
This is what I really need to figure out. If anyone with B20 PHK pistons have ever replaced their rings, and know what size to get.
