hi guy i’m very disapointed… the engine blow 2week ago now i putted a new engine running fine then 500km later start making a strange knocking sound.
It sound like a rod bearing! i posted a video below and you guy should hear better this way what i’m talking about! the thing is that it’s doiing the sound only from 1500-3900rpm after that sound disappear…
there you go
http://www.youtube.com/watch?v=qw80PnzvXS0
sounds like you have a bad valves or loose valves
damn hella loud ticking knocking sound. better check everything from head to the bottom block.
finally i unbolt the oil pack, remove strainer and founded a destroyed rod bearing
bad thing is the bearing is totalled out and has made a little little scratch in the crank
good thing is i’m trying to polish it out cust that was very minor! i need to wait until monday for the part store to buy new bearing!!
