rod bolts and cam caps
Been looking everywhere for the rod bolt torque specs, the haynes says 30ft lbs. Also need the torque specs for the cam caps. I just want to make sure I have everything right. Its for a stock b17a1. I called honda/acura and they claim not to have the info
Engine builders?
Engine builders?
23 lb -ft connecting rod nuts
8 x 1.5 mm 16 lb-ft
6 x 1.0 mm 7 lb-ft
Ok so the hanyes manual is wrong about the 30ftlb for the rod bolts? Damn
