Recently I noticed a slight braking performance decrease, and sometimes I hear whistles\squeeks when I brake slowly, say downhill, going 2.5ish mph.
The front pads still got 6-7mm, the rear ones are closer to 3-4mm.
I took some pictures of how the rotors are currently being worn down, tell me if this is proper, especially the rear ones.
Since it may a little tough to perceive dimension in those flash-filled shots:
Front right:
Front left:
Rear right:
Rear left:
It seems to me that especially on the front rotors aren’t worn on their whole surface, a few millimenters on the edge are untouched, which means the pads are touching down closer to the center, which is fine.
The rear though is a little tricky, it is almost as if that untouched edge is now being grinded down, almost the scenario i imagine if I was to replace the pads and not file rotors.
Please help.
