Rough acceleration under 3k
Its like when someone is learning how to drive standard. When they let up on the clutch too quickly and there a rocking feeling. If i had a old clutch i would assume it was slipping but i just changed it bout 3k miles ago. What gives?
check your vacuum hoses. the ones around your intake and stuff. pcv valve etc.
get a haynes manual for troubleshooting (pep boys- 15$). it will go step by step and tell you which and how to diagnose. also download the helmes (use the search) for detailed information
Sounds like your in need of a tune up. Cap/rotor/plugs/pcv and plug wires. Also do a valve adjust if you know how. Do you still have the old stock wires? If so get them checked with a DMM and replace if need be…Update us if it goes away or not.
i just had a similar problem…check your plug wires
i backtracked what my last installation was and it was a MSD blaster coil 2.
i put back in my old coil and the problem was solved.
