Rought start-up (long)
When I start the 92 GSR in the mornings, I get a knocking type of sound out of the motor. It doesn’t sound like detonation though, much lower in tone.
Also, the motor when I first turn it over revs to 1500 then immediately drops to 1000, then struggles to come back up to 1500. Finaly after a minute or two it arrives at 1500, the knocking noise goes away and the rest of the day it sounds and runs good.
The thing that is confusing me is that it only happens at the beginning of every day. If I leave the car sitting for 4 or 5 hours after warming it up and then start it and let it warm up again, no noise and it revs to 1500 and stays there until it starts warming up.
Thinking maybe cap & rotor or timing, gonna take care of both this weekend. Anything else I should look at while I’m out there? Could it be needing a valve adjustment even without the ticking?
Recently done:
New plug wires
New plugs (gapped correctly checked 3 times)
New fuel filter
Oil change
Mods:
ITR intake manifold
CTR cams
Aftermarket retainers and springs
Port matched throttle body
I/H/E
High flow cat
Adjustable cam gears
Chipped ECU running stock program right now
AEM adjustable cam gears with cover cut so they can be adjusted on the fly
Don’t know if this is related, but sometimes it seems like I can hear my valves opening and closing very well from inside the car.
i have this same problem can somebody tell us what is wrong.thanks
Wow a 2 yrs dead thread. But anyway to answer your question it may be alot of things.
To begin have you really done anything to the car? When and how it happen after or before u install something etc. Please give in details…
Note: if you are having idle problems do a search on “idle, idling problem”, etc. Its been cover and check the teg-tips for other helps related.
My question is(and it may be a stupid one) y is it idling at 1500 after a few mins, isn’t it supposed to idle at 750?
EDIT: y did i just bump a 2 year old thread?
