Rounded rear strut bolt
The rear strut bolt that goes through my coilovers and through the rear lca is rounded off. Its on there really really tight as I used a huge breaker bar to tighten it on there, and eventually, it wouldnt tighten anymore and just rounded off the bolt head. How do I remove? I already went ahead and ordered new rear strut bolt. Thanks.
they make a bolt extractor set that you can you I know craftsman has one
if you own a dremel, you can get a cutting wheel and zip it off in 5 seconds, or you can try some sketchy business and hammer a socket of similiar size onto it and hope for the best, ive seen it work haha. or try vice grips if you really wanna be dirty
Take a socket just a smidge bigger that you dont care about and weld to the bolt. Pounding on one a little smaller most likely wont work, be there and tried that.
I used this method before and it worked perfect.
K so the rear strut bolt I believe is a 17mm. I see this kit that I may try out but the kit has 11/16" which is the closest its got to 17mm. will it work?
