rpm's
my friend has aproblem with his teg, when he turns it on it doesn’t idle right, it does to 2000 rpm’s and after a while it goes down to 1500 rpm’s but the rpm’s are always high. he thinks it’s the throttle body, because the computer flashes 7 times and he thinks that there’ air coming in though the throttle body because it has two holes in it, but thats the way it comes. it’s not the computer or the map sensor, we’ve tried it already so if anyone can help thanks,
kb8thekid:up:
first off make sure you are reading the code right from the ecu. if it is 7 flashes then it means your Throttle Angle is messed up.
hhe prob tightened the cable too much.
