Rubbing on Upper Ball Joint casing
My car currently sits this high…
And my front left tire keeps rubbing on the Upper Ball Joint castle nut housing (there is a rounded groove in it).The tire has a defined area on the edge that is being rubbed out. I think it might be from shock travel, but im not too sure. I was wondering if I could order an adjustable upper ball joint and fix the camber so it doesnt rub, or if you have any other suggestions please let me know.
Also, when I shake the upper control arm, the left side in the back makes a knocking sound and moves around a bit. Could that be the bushing?
