when ever I make a hard turn to the right I can hear someting rubbing from my wheels. The noise started around the same time I had to fix three broken wheel studs and a new bushing (upper controle arm I beleive) Is there something that I could have done wrong to create this noise?
do your tires look like they would be close enough to be rubbing? more than 2" springs? larger offset? 17’s or greater? if so, you may need to get a bat and roll your fenders
Thanks for the suggestion but I dont think thats it cause my teg is lowered about 2 inches but it has stock 14in hubcaps on it.
