Running Rich??
I just got back from doing my emmisions test and I failed. I passed 3 out of the 4 test, I had to many hydro carbons at idle I think double what I was allowed. I also had .8% Carbon dioxide and your allowed 1%. The mechanic said that maybe my cat and O2 sensor aren’t working proplerly. What do you guys think?? Any help Appreciated. TIA
ttt
you can test the o2 sensor easily with a voltmeter. you can get one for like 10bucks at radioshack. invaluable tool imo. also pickup a haynes manual it tells you what to do. or download the helmes. try a search. also search for emissions tips ppl tried
If your running a stock setup then you will be needing a new catalytic converter. It just isnt burning up any of the unburnt fuels anymore.
There is a chance that it is your O2 sensor, but I doubt it.
Did you do a tune up before you went to do your test?? If you running bad spark plugs and/or cap & rotor then that could be your problem there. If your not getting a hot enough spark you wont be burning all of the fuel in the combustion chamber thus leaving lots of unburnt fuels, otherwise known as hydro carbons…
It is always a good idea to do a tune up before an emissions test.
Later,
BR
I did some what of a tune up, cleaned out my injectors with an intake solution, changed fuel filter and pcv valve. About 2 months ago changed my plugs (platnums) and wires(ngk). How much is a new cat?
60-80 i think. might as well get a carsound highflow cat for like 85-100.
