Runs for 15min. Shuts off, wont start till later. Then again.
I have a 91 gs that is having problems. The other day while driving the car shut off in the freeway. Did not know why. I started to do some research. Its trowing code 15 (ignition output signal). I have change the ignition coil, cap and rotor, spark plugs. I also checked the mrf good condition. The car starts if its cold, or has been sitting for a while. Then all of the sudden cuts off, it cranks over but it doesn’t start. If i let it cool off for a while it starts but then when it gets hot it turns off again. If anyone has any ideas or advice please feel free to let me know. Thank you.
probably igniter
x2
x3 happened to me twice, it was the ignitor.
X4 Had that problem twice, Its the ignitor.
Replace your ignition switch
Thanks
Thanks for all your advice, i went ahead and replace the whole distributor and went with 3-wire spark plug wires and perfect, the car is running awsome. Thanks again.
