ok, i tryed installing my SAFC on my b18a ecu (93 integra), i printed all the documentation from apexi-usa.com/documentation.asp and followed everything correctly and re checked it like 5 times…and the result was when i put it in the “on” position, the buttons would light up and the screen wouldent do anything, but then if you hit a button and held it down the program would start until you let go of that button…what do you think it could be? a bad connector? cause we used some easy splice connter things to piggyback all the wiring, and yes someone who has installed one before did all the work and i had checked the unit the night before i bought it offa this guy i know (so i know it all works fine), i just wanna know if there is any special webpages out there or anything special i have to do to get it to work on my 93 integra ECU… o btw the diagram i used was ha-2 which followed my pins correctly.
Thanks
