I was told that sanding a hood will cause holes in the hood? is this even true?
i plan to take 320grit with an orbital grinder and smooth it out so i can primer and base/clear coat it.
Is it an OEM or carbon hood?
oem
Its very unlikely that you will sand a whole through your hood, you should be fine. If you’re going to use the orbital grinder then use it on the lowest setting to avoid any problems.
You should use a da (dual action) sander
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93742
i got that one, i hope its the same
good?
That one looks like it may work ok.
