just wondering if anyone has used one of the ebay sandwich adapters?
all ineed it for is to run my oil pressure gauge sender to it
goods bads any comments at all are welcome
If the threads are good and the gasket surface seals its good. I dont see a need for spending more on a brand name adapter…
Just curious… what’s the port with the black and white wire coming out of it? Is that where you tap your oil pressure gauge into as well?
you can do any combo of what you want on the adapters. in that picture they have the oil pressure sender (gold/brass color) then the wires are oil temp i believe, and then oil feed for turbo
[QUOTE=integranewbie;2146278]just wondering if anyone has used one of the ebay sandwich adapters?
goods bads any comments at all are welcome[/QUOTE]
You may run into quality issues with a non name brand, but they aren’t complicated, so your chances are pretty good that it’ll work fine. They aren’t hard to make or anything. Just be sure to use teflon tape on all of your adapter threads (not the oil filter thread obviously).
I’m using an MFactory sandwich adapter and haven’t had any issues. - it looks exactly like the one pictured in that auction.
great info guys thanks…someone from here actually offered me a used golden eagle one for a good price so i guess im going with that instead of ebay haha
