Save the B17? or Tear it apart
I have a original 92 GSR, with a bone stock b17 motor, car just hit 202,000 miles on it earlier this week. motor runs fine, only problem the motor has is a slight cold start knock (unless you prime the car a few times before you start it) car has done it from the day I bought it from the previous owner. I bought the car when it had 170,000 miles on it. Taken good care of it and the knock doesn’t seem to be affect the motor at all. But I wanna add some more pep in my daily drivers step. I removed my p/s but I still have a/c and would like to retain it. Should I scrap the b17 and store the shortblock away and use the head for a mild built ls/vtec, or just put bolt-ons on the car and keep driving it? Reason I ask is I don’t feel like adding bolt-ons if the car will still feel gutless like a b16:p I miss the torque of my LS:squint: Any chance you guys think a all original DB2 would become sort of a collectors item one day? Cause I would hate to rip apart the block and pull the p61’s out:p
i would try to rebuild it with all original parts if you can find it and then add some bolt ons with a tune and it will have alot more pep
If you feel like building, I’d rebuild the b17a. If you feel like just swapping, I’d swap in a b18c-r. Overall cost between those two choices will be very similar. The b18c-r will make more power, but not a lot more power - assuming you build the b17a with similar parts to what the b18c-r comes with stock.
I got a 93 gsr. I had the motor rebuilt with better pistons bigger cams and added a bunch of bolt ons. I made 200 whp at church automotive. I’m going to through even bigger pistons and port the head next. The car moves way better than before.
