Saving the DB1
the part numbers are the same for the clutch cable between all three years so I would just take a second look over it and try again
Lol you got the 100th post
yeah il look into adjusting everything when i head out there today
I meant could i borrow the lip roller man nice work buddy im gonna miss you when your gone:bawl:
lol its not mine or i would let you
so today i was gonna start it and start swaping some stuff over from my DA but the battery was dead and they have to charge it for 8-10 hours cause its a optima lol… also had to wait for them to order my belts, so i just did some small stuff today i got the clutch cable to work the boot was pulled over a piece to much and wouldnt let it fully extend so got that figured out the bracket was looking a little rough so we blasted it and painted it
New Oil filter and Oil its ready to go just need belts and a Battery
Befor
During
blasted
Painted
I also liked how my “Spoots Intake” i made when i was in high school sounded so i made another one lol spoots is my last name backwards its a inside joke with me and my friends
We are gonna mod the hood so it will fit
Lol jk
Started with the stock lower piece removed the lower chamber
Cut it out
Cut my PCV pipe to length i wanted, used electrical tape to make a seal i know ghetto but it works really great
Big Sexy modeling the “Spoots Intake”(AKA Big C)
Now to plug up the other hole i used more tape and a piece off one of my BK crowns
First layer
The crown piece
Sealed
K&N drop in Filter
Finished
Hmm that gives me an idea. I got a couple flared sub box ports lying around
maybe it would work something like a volecity. Hmmm Steve what size is the PVC pipe diameter? Cool mod.
very nice, have you thought about putting a 90 degree bend on that and another piece pointing forward with a whole threw the rad support. kind of a cold ram-air setup:)
[QUOTE=teg cruzr;2058918]Hmm that gives me an idea. I got a couple flared sub box ports lying around
maybe it would work something like a volecity. Hmmm Steve what size is the PVC pipe diameter? Cool mod.[/QUOTE]
thanks its 3in
i was thinking about it, like running it infront of the VIP, it still works good were its at, when i had this setup on my DA it was very quite inside and had a nice tone outside, think im gonna order a ES tunning stainless oval muffler and just doing axle back for a clean look
lol that stock intake look familar hummm ebay ???
huh? you talkin about my joking one lol?
Werd, screw intakes. K&N drop-in is where it’s at! I’ve been running this set-up for years, it’s awesome
yeah this will do the same thing as a SRI and a CAI its just not a cool Ally tube all shiney with a cone filter lol i rocked this same intake in HS it rocked
Fuck yea! I’m on about 5 years for my filter haha :rockon:
yeah its cool, so today went put the new thermo housing on so i connect the iacv on the bottom of the tb but then when i was putting it back together noticed i dont have a spot for the line thats connected to the breather line off the vc that goes to the intake tube il post pics up in a min im on my phone wifes on the comp
heres a pic anybody know??
get a rubber cap and cap the end at the intake mani, you dont need that coolant to go through the TB but be sure you stick a hose clamp on the cap because it will shoot off
[QUOTE=Stevo-DA;2059488]heres a pic anybody know??
I just looked and it goes from IACV to TB, then from TB to the passage where the top radiator hose goes:
#7 here:
#11 here:
lol thanks bud, funny thing is this morning seth called me and i asked him to look at his DA to figure it out and i was on the phone reading what you posted right as he called me back, gonna go take care of this tomorow ^^
got some work done today, finished some wiring and put the bay back together just need belts and pcv hose, test fit the front end only reason bumper sags on driviers side is cause im missing the piece that holds it up
it was lookin a little rough so touched it up
Finished cleaning the wiring up
took the rear end appart to see if there was any damage found a small dent and think the rear bumper support is pushed in a little not to worried about it atm il fix it later, also befor the trunk wouldnt lock on the latch so i had to take it appart and ram it in lock it then bolt it back together… it will work tell i get a new latch
threw hood and bumper on lines up great
