whenever i roll up all of my windows theirs new scratches,ill post pictures of it tmr?
but is it the door?
ima newbie sorry.
should i take out the door panel and explore?aha
but is it the door?
ima newbie sorry.
is it all over the window or on the door speaker side and do you notice more resistance than normal.
ya not all over all in one warped spot.
pretty much towards the speaker side.
for sure will take pics today since it just sits there,cus needa replace alternator.
have you changed the door speakers with aftermarket ones and if so did you remove the speaker hole plastic adapter thing.
its most likely those little felt pad sliders that hold the window into place. they wear out and then start scratching your windows. They are easy to replace…Gotta take off the door panal though to reach them.
definitely the felt slide pads i have the same exact problem and i came across a service bulletin at my automotive class at school.Heres a link http://www.g2ic.com/forums/showthread.php?t=91979&highlight=window+scratches
wow thanks link really helped.
so get 92 93 door glass stablizers and replace door glass both front left and front right?
right?ha
you dont need to replace the windows unless the scratches are extremely deep heres a another articlehttp://www.g2ic.com/forums/showthread.php?t=183700&highlight=window+scratches that tells you a way you can try and remove the scratches for farely cheap but everything else you said is correct just purchas the new stablizers i looked up the part number and found that each stabilizer is about 12.00 a peace.
12 bucks a piece damn
didnt the acura technical severice bulletin say it was only 90 and 91’s that had glass stabalizers that scratched the windows
so if i get a 92 93 glass stabalizer and new windows would be way better
cus for 12 bucks i can test my luck with my five finger discount at my pick n pull if its small enough ha.
keep that on the DownLow though ahah
no prob keep us posted.
