can anyone post or help me post a step by step with pictures or maybe a video on the proper way to seafoam our cars…
Put the brake booster vaccuum hose in the bottle.Have someone rev the motor so it doesn’t stall. Use 1/3 or half. Turn car off. Wait 5-10 mins. Turn car on. Drive around the block. Pretty straight forward.
Pretty sure there are directions on the back of the bottle.
Yep that what I did well have thru the booster half in the tank with gas on three cars no problems
[QUOTE=TegFan;2165579]Put the brake booster vaccuum hose in the bottle.Have someone rev the motor so it doesn’t stall. Use 1/3 or half. Turn car off. Wait 5-10 mins. Turn car on. Drive around the block. Pretty straight forward.
Pretty sure there are directions on the back of the bottle.[/QUOTE]
so what are people talking about putting some in the engine through the oil thing on the valve cover?
How good is this to do?.. Benefits?.. When should this be done?
i have seen people put some in the oil and the gas tank and the brake booster. I believe all 3 at once is overkill but im no rocket scientist !
It say you can put it in all three but I have only done the two I will put it in the oil one of these days tho
they say it cleans out all of the carbon build up in your motor. people have compared it steam cleaning the inside of your motor…
i would assume the benefits would be a cleaner motor and idk when it should be done. every so often i assume…
