seat belt light stays on
Imma ck the seat belt switch, but it has to be something with the retractable belt cause I lean foward and it chimes. That switch is behind the panel right?
my 90 ls has the light on too and everything is plugged n looks good so my solution pull the gauges out n disconnect the light u dont need it anyway
ya but u need the seatbelts to work. mine don’t seem to lock up when it chimes at start up. But it’s wierd cause it doesn’t chime til I lean foward. Anybody got insite?
i took off my drivers side door switch and cleaned the contact point worked for me but i still need to make the door close tighter…to try it out when it is beeping pull ur door tighter…give it a try . let me know
not saying to disconnect the power to the seat belt just pull the stupid light out it should just be a bulb. my seat belts work just fine and like i said before everything looks and is connected tight and my lights on.
i know this is a old thread but i recently rebuilt my DA and im running a Recaro bucket but using factory belts. i dont currently have a passenger seat at all and cut the wiring that normally plugs into the buckle. would this cause the dash light and beeping to go off constantly and if so is it poss to just wire it the system to itself to “trick” the system to believing that the seatbelts are buckled.
