im having this problem with my seat belt. When im driving and then brake kind of hard my seat belt move foward, wen the car its fully stop it goes back again…im just scare cause in a accident is not gonna help at all…any help
I had the same issue with my passenger side turns out that my door would close but whenever i turned the momentum would cause it to open slightly and the belt would move to the door open position. so i adjusted my door lock stricker so that the door closed better and problem solved. hope that helps.
where is the door lock stricker located at ?
it’s the silver loop by the door switch. it is chrome. i didn’t know you could adjust those…
That would Suck… Glad im getting 5.P.H. soon… good luck
