Seatbelt light won't stop flashing and beeping
Yes, I did a search. Yes my seatbelts are plugged in under the seats. That being said…
I got in my car the other day with having done no work to the seats in the past year and out of the blue my seatbelt light starts blinking quickly and beeping the entire time my car is on. When I unclip my drivers side shoulder belt, the blinking slows down to a slower rate, however when I unclip my passenger side shoulder belt, the blinking and beeping do not change. This leads me to think that my passenger side is where the problem is.
Any clues as to where to start looking? I’ll take it to a dealer as a last resort, and once again, the connection under the seats are plugged in.
Thanks for any help.
-Steve
I went crazy!
I know you said that you did not do anything unusual to the seats but if it helps i had a similar problem. I Installed the 99 integra leathers and had to cut the wiring, thats when my prblem started. After a few months of this constant beeping noise i lost it. I grabbed a pair of wire cutters, reached under the seat, and went crazy til the light went off.
Re: I went crazy!
all you had to do was create a jumper with a paper clip or something.
Whats that all about can you explain?
i installed del sol seats in to my teg so i know that in order for the beeping to stop you have to close the circuit from the seat belt wire harness. so once unplugged close the circuit with a bent paper clip or something.
bump
Steve, did you figure this out?
It stopped on its own the next day. I have no idea why any of this happened.
-Steve
Cool beans. Hope it doesn’t happen to you again :up:
wait im having this prolem now… but i did change my seats to black… what exactly do i do now??
