i removed my stock passenger seat to install rsx seat. how do i disable the warning chime and light. i know i can unplug the icu but i think that disables fogs, intermittent wiper and rear defrost. i plugged the harness back in from the shoulder belt, but i still get warning light and chime. fcm you out there, i know this is your specialty
Try installing a jumper on the seat belt plug. 94
Sorry to jack your thread. But that might be a good idea for my situation. Fcm, is the connector a two pin? Another question is, if I disconnect these seat belt plugs, will shoulder belt still function? Meaning will it still slide on its tracks?
My car is in a storage facility so I cant conveniantly check this out. Thanks
OP- So if you installed an Rsx seat, I assume you don’t need the sliding shoulder belt right? And you wanna eliminate the chime? You can do what FCM said OR you can disconnect the two plugs on the “seatbelt control module” located on the lower passenger side behind the kick panel. Its a dull silver box.
